BGP.PolicyMgr.RtNotAdvertNHSameTxPeer
Description
A route can not be advertised because its next hop is the same as the address of the peer to which it was being sent. The route will not be advertised to this peer.
Remedy
If the route should be advertised to the peer, set the bgpPeerCheckNextHop field of this peer's entry in the bgpPeerTable to AMB_FALSE. This will prevent the next hops being checked against the peer's address.
Severity
Info
Message Text
A route can not be advertised because its next hop is the same as the address of the peer to which it was being sent. VR: %p1% Neighbor index: %p2% Next Hop Address: %p3%
Message Parameters
Name Type
p1 uInt32
p2 uInt32
p3 VarFmtByteArray
